05-31-2021 06:50 PM - edited 01-06-2022 02:48 AM
My phone is showing only 2 bars and often gets disconnected when I am on the phone. Anyone else experiencing this issue? Any work around?
05-31-2021 06:55 PM - edited 05-31-2021 06:58 PM
do one thing take your SIM card out and waiting for a minute and put it back and do rebooting your phone - This one is quick and simple. Make sure your phone is off before removing and reinserting its SIM card.
Remove your phone’s battery - Some phones have removable batteries. Sometimes removing and reinserting the battery can fix certain issues. Just make sure your phone is off before you do this.
what is mean for Rebooting the phone means to turn off your phone and turn it back on again.
or if still have the issue you have to Submit a ticket to a moderator.
Here’s when and how to contact the Moderator Team:
Good Luck
05-31-2021 06:54 PM - edited 05-31-2021 06:55 PM
@PunjabMoga wrote:My phone is showing only 2 bars and often gets disconnected when I am on the phone. Anyone else experiencing this issue? Any work around?
@PunjabMoga when active on a all you should have a stronger signal (more bars) then when not on a call.
Where are you located, in the Manitoba, by any chance?
if you are totally losing the bars on your phone then force your Mobile Connection to 3G, or what other settings you have on your phone...the bars will increase.
You should go back to Auto select though when out and about if you ever want to use your data.
Here is a link for a coverage map.
https://www.publicmobile.ca/en/bc/coverage
Canadian Cell Towers
http://www.ertyu.org/steven_nikkel/cancellsites.html
