Vivo X70 Pro Plus
gstone99
Does anyone have any experience with this phone on Public Mobile?
@gstone99
my advice to you to you buy it a iphone or google pixel 6 pro, is better and is around same price,
I dont think this phone has a Canadian version.  However, look like both China and India version have the proper bands used on PM.  So, it should be good in terms of the spec
pkaraa
It is a good phone with better camera quality and 12 GB RAM less updates expected than the V, Y and Z series.
Just make sure you are buying the Canadian version so the frequencies will match(mentioned above) with Canadian providers.
@gstone99
is will working with Public Mobile
visit Here link to you can check it full information about your device.
Public Mobile uses the following frequency bands:
  • 4G LTE and LTE Advanced: 700 MHz, 850 MHz, 1900 MHz and 2100 MHz downlink and 1700 MHz uplink (AWS).
  • HSPA: 850 MHz, 1900 MHz (UMTS).
Vivo X70 Pro+ review..
Good Luck.
