Visual voicemail?
os54656
I have the google phone app on my phone. Does public mobile have visual voicemail or is this a glitch (probably a glitch)?
@os54656
I'm using my fongo free number for voicemail, i just forward all the missed calls to it instead of Publicmobile VM number.
I get more (no clue how many) voicemails and i get copy of them by email, i also can get more rings before voicemail if i wish.
Also i don't have to use my 100 minutes to call into voicemail, i can call in using app too
Give it a try if you would like such option, it's free
os54656
Alright, thanks. Just thought I'd check just in case.
Dunkman
@os54656
Unfortunately, Public mobile does not have visual voicemail.  Low cost, no frills mobile carrier.
