Verifying identity
Kyah14
I had my phone stolen recently I’m just trying to update my sim in my new phone unfortunately I can’t authenticate my phone number because of my lack of phone right now . I’m not sure where to go from here
2 REPLIES 2
hi @Kyah14
you can try to get the code via email or voicemail (call yourself from another phone).  On the 2FA screen, click Didn't Receive Code or Resend code, then you can choose Send Email or Send Voice Message
but if that does not work, you will have to submit a ticket with PM support agent and ask them to update the sim card number for you, you can submit  ticket by direct message:
slusagm
Click Didn't Receive Code or Resend code and choose Send email.  If no such option, ask PM to help to update the sim card number
Since you cannot properly login, you won't be able to open the preferred Chatbot ticket.  So, you will need to message them here:
