Use same phone number
09-23-2020 11:51 AM - edited 01-05-2022 01:19 PM
09-23-2020 01:34 PM
Yes just make sure the number is active and that you have your Koodo account number. You can even go to a physical location in a mall that sells Public Mobile SIMs and have the clerk transfer it over for you and setup auto pay.
09-23-2020 12:03 PM
@gabrielpresidio wrote:Can I use the same phone number that I have from Koodo?
@gabrielpresidio If you are a Koodo postpaid customer and are thinking of switching to Public Mobile then you can port your number during Public Mobile sim activation session. Otherwise if your are currently a Koodo prepaid customer have your Koodo account number, name on the Koodo account and Koodo number ready. Click this link and type in “port request” to be put in touch with a Moderator and provide the Koodo info from above.
09-23-2020 11:54 AM
You can port your phone over to PM. You will need to submit a ticket to a moderator.
Here is more information.
09-23-2020 11:53 AM - edited 09-23-2020 11:55 AM
You sure can.
You need a PM sim card. During activation there will be a section to enter the information to port your Koodo number if it's post paid. If it's prepaid Koodo during activation sign up with a new number and after account is created then click the question mark bottom right to open the chat bot. Type "port request" to submit a ticket to moderators to transfer your number over.
Dont forget to use a referral code for a $10 sign up bonus.
Welcome to Public Mobile 🙂
09-23-2020 11:52 AM
Yes, you can port that number to PM.
09-23-2020 11:52 AM
You can port in your number from Koodo (postpaid) when you activate. If you have Koodo prepaid then you must activate with a temp number and message the mods for porting.
