Usage History question?
08-10-2018 10:07 PM - edited 01-04-2022 06:43 PM
On my PM iPhone I get the following...
Is this PM sending this or Apple?
I am on the $10 plan with no data.
My Account
08-11-2018 11:20 AM
@TMS wrote:
@happycamper wrote:I have the $10 per month plan - no data - but I got the data add on....I have used it mayber 2-3 times and for only maybe 1 or 2 minutes in 2 months....my cellular data on my iphone is turned off...yet there is data leakage recorded almost every day....over a 2 month period I have used approx. 2-3% of my add on....not a big deal but over time it is being eroded not by my usage.
Thanks so much. - Apple is requesting our personal info. - Do use "Hey Siri"?
no...don't use Siri
08-11-2018 11:19 AM
*you
08-11-2018 11:18 AM
08-11-2018 12:28 AM
08-10-2018 10:44 PM
@Gel-Doua wrote:@Dunkman there is no sms on his history, @popping was right, he has no data, and his mobile has data enabled, so when mobile try to connect, this is what he get.
Yes. Earlier, when I restored the iPhone Apple requested something and 6 sms were sent from my iPhone.
i ll have to turn off my data. Although, I thought I did previously, but phone isn’t presently with me. 😉
08-10-2018 10:38 PM
08-10-2018 10:33 PM
@popping wrote:Your iPhone may have the mobile data enabled and was trying to use data. Your plan does not include any data. PM was blocking your iPhone from using any data without data add-on.
Any chance this could be messing up SIRI? It says I have a network issue. And since Apple doesn’t receive the response from my iPhone, because of the lack of data on my plan, SIRI delays her initial response to my “Hey Siri” question.
08-10-2018 10:21 PM
Same exact thing happened when I started with my iphone with Public Mobile. My iphone sent about 10 messages within the first 24 hours. I contacted moderator, who added 10 extra text messages to my account for that month. It is a known issue with iphones.
08-10-2018 10:17 PM
08-10-2018 10:14 PM - edited 08-10-2018 10:19 PM
It's your iPhone. I believe it's syncing for the initial setup.
