Us can plan ending
stimpy
 The US can plan is ending soon.
Will I continue to get the same plan after the end date if I don't change my plan?
2 REPLIES 2
hairbag1
@stimpy
long as your plan stays active and up to date...you 'll keep that plan as long as you want it.
Sansan
@stimpy  yes you will. It doesn't affect you.
The expiry is just for new customers who want to sign up today.
