Upgraded offers
BLEE
Hi,
since I've purchased my plan, I see that the later plans offer more data (50gb) for the same price.  Since I haven't activated my plan, is it possible to receive the upgraded data in place of my original 30gb plan?
Thanks!
1 REPLY 1
HALIMACS
Sure is @BLEE
Just ask the customer support agents NICELY and they may accommodate the change for you.
But act fast as the offer is likely expiring within several hours!!!
To contact a Customer Support Agent, send a private message to them by clicking here.  You’ll need to be logged into your Community account for the link to work.
Watch for their response in your Community private mailbox which will be indicated by a number on the small envelope icon to the left of your Community avatar, or tap your Avatar down in Messages.
