Upgrade to iPhone 11 Pro Max from iPhone 7 Plus
lolaww724
How do I transfer information from iPhone 7 Plus to iPhone 11 Pro Max?
Do I need to buy a new chip from PM or do I just move the one from the iPhone 7Plus? What do I do first?
7 REPLIES 7
lolaww724
Great!
Thank you for the detailed step by step, how to, transfer to a new phone!
Cheers!
gpixel
@lolaww724 first backup all your info on the iPhone 7
  1. Open Settings on your old iPhone
  2. Tap the Apple ID banner.
  3. Tap iCloud>Tap iCloud Backup>Tap Back Up Now.
  4. Turn your old iPhone off once the backup is finished.
  5. Remove the SIM card from your old iPhone and install it in the new iPhone
make sure your old iPhone is turned off
  1. Turn on your new iPhone
  2. Slide up.
  3. Follow the directions to choose your language and set up your Wi-Fi network.
  4. Tap Restore from iCloud backup.
  5. Sign in to your iCloud account (This is your Apple ID).
  6. Tap Next>Tap Agree>Tap Agree again.
  7. Choose the backup you just made
gblackma
@lolaww724 If its a brand new phone, insert the SIM and restart the phone. Stay safe.
tabi159w
You don't need to do anything related to Public Mobile. Just transfer the SIM and you should be good to go.
geopublic
@lolaww724  You just move the sim from the old phone to the new one. Public Mobile SIMs are tri-punch so if the sim is too large just punch out to the smaller size.
Jb456
Take sim out of old phone put it in new one. Then transfer your stuff from the cloud.🙂
Naepalm
@lolaww724
If you are already a PM customer just insert the SIM from your iphone7 into the Iphone 11. Make sure the 11 is unlocked.
Once the SIM is in restart the phone and the network should pair. And your on your way.
Cheers
