Update from 3G to 4G - what happens to current data bonuses
ve7rhf
Currently I am on a 3G plan. I have several free data add ons with lots of data remaining - will they use 4G if I upgrade my plan to 4G?
maximum_gato
@ve7rhf
Once you change from a 3G plan to a 4G plan it will take up to 48 hours for your 4G LTE data speed to be unthrottled from (up to) 3mbps to (up to) 100mbps.
Add-ons work at the same speed as your plan data.  The add-ons will work at the new faster speed after making the plan change.
Jlund
You will not lose any bonuses or rewards.
