07-17-2019 07:54 PM - edited 01-05-2022 05:56 AM
I had my cell phone stolen. I now have a loaner phone as a temporary solution. Trouble is I bought a new sim card, but can't seem to use it with this phone. I believe the phone is locked to a carrier but no clue which. Can someone help me out?
07-20-2019 07:36 PM
@robertmayThat's painting the whole industry with one broad stroke.. like EVERY industry there are good and bad..
07-20-2019 07:19 PM
phone kiosk staff is the lowest quality staff in any industry, by a wide wide wide margin
07-20-2019 01:48 PM
@MikePysh great glad your so smart ![]()
07-20-2019 01:44 PM
I got the phone working. I reseated the SIM and voila! It worked!
No thanks to the incompetency of the kiosk employee at Orchard Park Mall.
Thanks peeps!
Mike
07-18-2019 09:00 PM
Try this?
07-18-2019 01:11 PM
You used to have to pay money to get your phone unlocked if it was locked to a carrier, but because of new laws the companies that it could be locked to are now required to unlock your phone for free if you give them a call.
You can try googling on your phone to find out which carrier it is locked to
07-18-2019 02:19 AM
07-17-2019 10:31 PM
Can you see any bloatware from any carriers? Telus app, bell, Rogers etc? If the phone was from one of them it should have apps there or disabled. Usually a sign.
07-17-2019 09:17 PM
@nwahkan wrote:rogers and bell are the two biggest competiontions, they also own all of the other sub copamnies like public (bell) so what i recomend is email on the bell website like the costemer service rep and they will ask you for the serial number of the phone and they will unlock it
Public is owned by Telus.
07-17-2019 09:11 PM
07-17-2019 08:08 PM - edited 07-17-2019 08:09 PM
@MikePysh Not sure how to tell which carrier the phone is locked to. May be you can try entering the imei number on some website that tells you that info. If not, then you might want to try sim cards from different carriers (Rogers, Bell, Freedom, etc) to see which one works or does not ask to enter pin/locked code.
EDIT: have you changed the sim card number from your self-serve account? This might be the reason you are not connecting to the Public Mobile network.
