‎12-16-2018 03:26 PM - edited ‎01-05-2022 02:49 AM
I just bought a phone that is from Verizon (which works with any sim card) so calling and texting works for me however data does not. It just says H. Please help
‎06-14-2019 08:46 PM
Finally, been poking around all day trying to get images received and the above configuration was the one that worked on my Verizon unlocked Galaxy S7. Thank you.
‎12-16-2018 03:35 PM - edited ‎12-16-2018 03:37 PM
You likely need to update your APN settings.
Android
Settings > More / More Networks / Wireless & Networks > Mobile Networks > Access Point Names > New APN setting (or a plus sign)
Iphone
Settings > Cellular > Cellular Data Options > Cellular Network
Settings > Mobile Data > Mobile Data Options > Mobile Data Network.
Name: Public Mobile / Mobile Internet
APN: sp.mb.com
Proxy: Leave blank
Port: Leave blank
Username: Leave blank
Password: Leave blank
Server: Leave blank
MMSC proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
APN protocol: IPv4
APN roaming protocol: IPv4
Bearer: Unspecified
MVNO type: GID
MVNO value: 4D4F
