Unauthorized access
KirstyS
I can't log in, and when I do, it says "unauthorized Access". It won't let me log in, and it won't let my call or do anything. Please advise
2 REPLIES 2
slusagm
You might need PM to check and  help
 Since you cannot properly login, you won't be able to open the preferred Chatbot ticket. So, you will need to message them here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
https://productioncommunity.publicmobile.ca/t5/notes/privatenote
TheSterlinger
@KirstyS  is this a new set up?
On the page for the 6 digit, so you see the message Didn't receive this code? If it does have you tried clicking on it. It will give the option to send to email.
If it still doesn't work, please message directly to csa  at the link below for assistance.
