Unable to use data
06-04-2018 12:16 PM - edited 01-04-2022 06:06 PM
I use a iphone 6s plus, and since a few months ago I realized I can't use data anymore.
I have had no prior issues with data and no settings have been changed.
Things that I have tried:
- restarting phone (it works for a bit, then doesn't after a while)
- checked APN settings
- made sure I have data remaining on account.
Please help
Phones
06-04-2018 02:20 PM
Hello ssfreaky,
Thank you for reaching out to us.
For reminder, you need to make sure to set the right APN by referring to this link: https://productioncommunity.publicmobile.ca/t5/Knowledge-Base/Setting-up-Data-APN-on-your-phone/ta-p...
In order to better assist you in regards to your data usage issue, please send us a private message.
Cheers
Abdoulaye
06-04-2018 01:51 PM
I'll give this a try. Thanks
06-04-2018 01:32 PM
@ssfreaky did you try to update to newest iOS by OTA? If yes, I recommend you should restore & update via iTunes that makes your phone smoother. I got that problem before but after I restored via iTunes everything is good until now 🙂 good luck
06-04-2018 12:37 PM - edited 06-04-2018 01:06 PM
You might find this helpful for troubleshooting: click here
If you have recently upgraded your iOS, you may consider downgrading it.
EDIT: Go to Settings > General > Reset > tap "Reset Network Settings". The phone will automatically restart. Let me know if this solves your issue.
