11-25-2022 04:07 PM - last edited on 11-25-2022 04:09 PM by computergeek541
I have tried multiple cards and I have funds in those accounts but it always says that there’s a problem. I have tried every day for the last 5 days. Just looking for some help before my account gets suspended
11-25-2022 04:09 PM
@PhoenixFast wrote:I have tried multiple cards and I have funds in those accounts but it always says that there’s a problem. I have tried every day for the last 5 days. Just looking for some help before my account gets suspended
To figure out why mutliple payment cards aren't working, please open a ticket using the chatbot and get the help of a Public Mobile customer support agent. https://widget.telus.tiia.ai/publicmobile/publicmobile.html
In the meanwhile, a Public Mobile payment voucher can be puchased from some local convenience and grocery stores. After purchase, they can then be applied to your Public Mobile account using Self Serve or by dialing 611.
11-25-2022 04:08 PM
@PhoenixFast try once more using Private or Incognito mode
If still same, open ticke with CS agent:
at : https://publicmobile.ca/chatbot.
First type Contact CS Agent,
from the list of , choose "Other"
finally click the the blue link about submit a ticket
