Unable to Access self serve
12-04-2019 01:58 PM - edited 01-05-2022 08:18 AM
Unable to figure out which email was used for registration... When using "reset password.." it's unable to find an account with the specified email... Can a moderator please help.
My Account
12-04-2019 02:14 PM
yup.....read here. The portal is plugged. They are having a sale.
12-04-2019 02:14 PM
You would think - better communication would save a lot of problems with PM.
12-04-2019 02:13 PM
I've submitted a ticket. At a minimum, there really should be a proper error message letting the user know that the error has been acknowledged at that the Public Mobile software team will be actively working on the issue. Ideally, it should say when the issue was first noted and what the ETA is, perhaps even with an email/SMS entry to be notified when the issue is fixed.
12-04-2019 02:10 PM - edited 12-04-2019 02:11 PM
I don't think a ticket is needed!!!! I cannot logon to My Account from iPad or Macbook. Have tried several times this morning. Is there a super sale on something??
12-04-2019 02:08 PM
Does this happen often?
12-04-2019 02:06 PM
Probably opening a ticket then would be your best bet.
12-04-2019 02:04 PM
Thank you both for your replies, I haven't been able to log in for months so it's not a temporary issue.
12-04-2019 02:03 PM
You won't be able to log in to it anyway, it's been down for an hour now it seems. This just isn't good enough.
12-04-2019 02:00 PM
Moderators don't frequent threads, you'll need to submit a request. Start off by hitting the ? icon on the bottom right hand corner of the screen and follow the steps.
And in the meantime, you can try contacting *611 on your phone if you need to check your account.
Good luck!
