10-22-2017 08:32 AM - edited 01-04-2022 02:48 PM
Good morning ! Looking for a bit of help 🙂 Would the Umidigi Crystal get reception on the Public Mobile Network (Telus) ? Thank you as always!
2G: GSM 850/900/1800/1900MHz
3G: WCDMA 900/2100MHz
4G: FDD-LTE 800/1800/2100/2600MHz
10-24-2017 07:25 PM
@Acekiller wrote:never head of this phone before, is it any good?
@Acekiller http://lmgtfy.com/?q=Umidigi+Crystal+review 🙂
10-24-2017 02:20 PM
10-23-2017 09:57 PM
It will work on the Rogers network thats it.
10-23-2017 01:02 PM
This is a beautiful phone! ![]()
10-23-2017 12:23 AM
@will13am wrote:This phone will not work on Public Mobile or any Canadian network for that matter.
Yes, and no, respectively. Definitely not compatible with Telus/Koodo/Public Mobile/Bell/Virgin Mobile. That said, it will worth with Rogers and Fido, since they operate a 2G GSM network that this phone will work with for phone and text and (extremely slow) EDGE 2G data.
10-22-2017 03:57 PM - edited 10-23-2017 12:31 AM
On Public Mobile, LTE can only be used for data. The Band 4 LTE that william mentioned isn't the only LTE band that Public Mobile customers have access to, but it is the primary one.
This phone might work for internet use, but only in a limited amount of places (on 2600MHz). And remember, voice calls won't work at all, not matter what, anywhere when using Public Mobile on the Telus network.
You'll want to choose a different phone.
10-22-2017 09:11 AM - edited 10-22-2017 09:15 AM
This phone will not work on Public Mobile or any Canadian network for that matter. It lacks the necessary 850, 1900 MHz on 3G. You need this for talk. For reliable LTE, 1700 MHz is needed. This site is great for checking phone compatibility.
