02-13-2026 04:10 PM
I bought the Canada USA plan and entered the uSA and I have no data or phone service
02-13-2026 08:53 PM
@TeresaThiessen all phones have that toggle. Usually in the Mobike data screen.
What phone you have? Will look it up for you
02-13-2026 08:50 PM
I don’t have an option for roaming
02-13-2026 04:58 PM
won't be VoLTE issue since you hvae problem with data
02-13-2026 04:14 PM
what phone do you have?
Mobile data should not be hard to get, but you need to make sure you turn on Roaming Mobile data, many missed that
and confirm if your phone connects to AT&T or T-Mobile or Verizon. If the one connected does not work, change the Mobile connection to Manual, try manually connect to each of the three. one of them should work
02-13-2026 04:12 PM
make sure you turn on Roaming data
and change the connection from automatic to manual. Try the 3 networks: T-Mobile, AT&T, Verizon
