US texting
catman2
Can I text to Canada when I’m in the states and have the US talk and text add on?
@catman2
You can purchase a 10 day unlimited Roaming text to Canada for $8.
Or you can download the TextNow app and get free calling and texting while in the USA.
dust2dust
Talk may be spotty. And as always, with all providers, coverage may vary. If talk doesn't work then see if you can change your phone to 2G/GSM only. Then change back.
@catman2  if you have US ROAMING Talk and Text addon, then YES.  You can send and receive Text (and calls) when you are in US
Make sure you connect to T-Mobile network.  If the phone Automatic settings cannot connect, try to manually connect
