US roaming
04-29-2023 03:07 PM
04-29-2023 03:11 PM
Do you see the add on in your self service account? Do you know if your line has VoLTE service yet?
Try to reboot your phone
Connect to T mobile service. For talk try to connect to 2G network (if not VoLTE).
Here is some more information:
https://www.publicmobile.ca/en/on/get-help/articles/us-roaming
04-29-2023 03:10 PM
Are you in the states? Whereabouts? Make sure your network setting is on automatic or scan for T-Mobile. Text should be able to work depending on where you are. As for all providers though you need to be in their coverage area.
