US roaming
Love2travel
Looks like the US roaming is only good for 15 days. How much time before you can do another 15 days US roam add on?
Indeed you do, @Felmoha
Customer support needs to initiate the rebuy of the same US roaming add on within 24 hour expiry of the first.
Yes – a stupid glitch, one I still don’t quite understand the logic for.
Felmoha
You can start it as soon as you want. You don't have to wait.
And just to clarify what "0/15" means,  @Love2travel , that's the add on counter available in your self-serve page for reference.
It'll start at 15/15 when purchased.
dust2dust
Just to clarify what "earlier" means. When the existing add-on days goes to 0/15 then you can buy the different add-on. That's exactly 360 hours after you bought it. You could buy different data add-ons before 0/15 though.
Dunkman
@Love2travel
To renew the same 15 day US roaming package, you normally need to wait 24 hours after the package expires.  You could purchase a different US roaming package earlier.
You can contact customer service agent to renew the same package before the 24 hours.
