11-03-2018 01:07 PM - edited 01-05-2022 02:23 AM
I purchased a US roaming add-on, but it doesn't work. Any ideas?
11-07-2018 11:09 AM
11-04-2018 05:27 PM
Yes, the add-ons do work because I have purchased them as well. They seem to work great!
11-03-2018 08:38 PM
@mjoeck wrote:Sorry, I pressed accept as solution by accident. I purchased a $20 add-on for texting, calling and data. My available funds was reduced by $20. I activated cellular data roaming and restarted the phone. Yet I can't do anything on roaming.
So now you see the add-on down in your add-ons area of the overview page?
It's not *just* cellular data. It's simply a roaming option. Then you need to get connected to either t-mobile or at&t. You might be manually set to Telus/Koodo/PM. You need to be able to scan and find the US providers.
11-03-2018 08:25 PM
11-03-2018 08:23 PM
@Moderator_Team It's still not working. I activated cellular data and restarted the phone, yet every time I try to use data a box pops up that says I need to activate cellular data- even though I already have. I'm feeling very frustrated. I'm going to leave the US in 20 hours, so I don't need the roaming any more, and haven't been able to use it. I would like a refund for the add-on.
11-03-2018 04:38 PM
@mjoeck wrote:@Moderator_Team I've now spent $20 on US roaming, but it's not working. I purchased it yesterday morning. Am returning to Canada tomorrow. I'd like to remove the add-on given that it's not working...
I suspect it is one of the 2 points that @Anonymous mentioned. If you had purchased the $10 US roaming the first time you would not be able to purchase that same pkg again until the first expired. (10 Days)
11-03-2018 01:32 PM
@mjoeck, If you still can't get it to work after following @Anonymous 's tips, you can contact the moderators via private message when you return, and see what they can do for you.
Click here to send the moderator team a private message. Their hours are: Mon-Fri 9AM-9PM(EST) & Sat/Sun 9AM-7:30PM(EST)
You can find information regarding the moderator team by following this link.
11-03-2018 01:12 PM - edited 11-03-2018 01:14 PM
Did you do the two steps?
1. add money to your account.
2. buy add-on
If your Available Funds shows the amount in step 1 then you didn't do step 2.
Then also restart your phone. Turn on the roaming option in your phone. Find T-Mobile or AT&T.
11-03-2018 01:08 PM
