US roaming and data
Berkley11
I purchaced a $20 us roaming and data add on on friday august 5 and the service was absolutely useless. I was at Michigan raceway and was able to use it about 5 times. I have used this many times and never had this problem before. I would like my money back. Very upset with this. Al
Berkley11
Problem solved. Thanks
HI@Berkley11   did you try to connect to both  T-Mobile and AT&T and see which one works better?
Yes, if the roaming wasn't working out, open ticket with CS agent and complain, the might reverse the transaction or work out some compensation:
at : https://publicmobile.ca/chatbot. Follow this to get to ticket open screen quicker:
start by typing : Contact CS Agent
then Click "Contact Us"
then Click "Other"
finally Click "Click here to submit a ticket"
MrSpock
@Berkley11 hi for a refund
you will need a customer service agent,
 to speak to a customer service agent    Click here or if you are having issues with Simon you can send private message to a CS Agent here:  https://bit.ly/2GGCJzH
Timer
@Berkley11
contact to support team by private message CS_Agent  to them check it out your account.
