06-01-2026
01:38 AM
06-01-2026
07:39 AM
Did this end up working for you? I tried this previously but it never worked cause you needed a physical SIM. Not sure if it works now.
06-01-2026 07:41 AM - edited 06-01-2026 08:03 AM
YES, US iPhone is compatible with PM network, even those newer eSIM only models. Many subscribers are using them on PM network
Some people were advised to use a physical SIM, but the issue was not related to the iPhone being a U.S. model. Instead, those cases were caused by activation problems.
So, you can use your US iPhone here
