02-25-2022 11:41 PM
I added US Roaming Bundle but I must of entered it twice but I only need one. Added before leaving Canada and once I got to Florida it didn’t work. How do I cancel one or both since I haven’t used them.
Add-Ons
02-27-2022 08:21 AM
Yes there was a double charge.
02-26-2022 02:00 AM
@Ludie : Click on Plan Details and tell us what all lines are showing in there under add-ons.
Maybe you bought the talk/text/data bundle. What didn't work? Nothing? Or any one of them?
Maybe you also only deposited money and didn't complete the purchase.
For talk, you'll need to connect to T-Mobile.
If you buy multiple talk add-ons then you'll have a problem.
02-26-2022 12:40 AM
Check your Self Serve account and look under My Data and Add-ons to see if there was a double add-on and charge.
If there are 2 roaming add-ons, you should contact a CS_Agent to cancel 1 add-on.
02-25-2022 11:44 PM
@Ludie wrote:I added US Roaming Bundle but I must of entered it twice but I only need one. Added before leaving Canada and once I got to Florida it didn’t work. How do I cancel one or both since I haven’t used them.
The system isn't supposed to allow you to add to of the same roaming add-on, and I suspect that may be why it didn't work. Please open a ticket to discuss with a CSA by going to: https://widget.telus.tiia.ai/publicmobile/publicmobile.html
