11-09-2017 02:47 PM - edited 01-04-2022 02:55 PM
I’m currently still in the US with the US Roaming Talk and Text plus 1GB Data add on. Because where I am staying does not have WiFi, I am totally relying on my data. As a result, I have already used over 80% of my data in 2 days. I want to add another 1GB plan, but it is not appearing as an option. Seems like I have to choose either the 500MB or 25 MB options. If and when my 1GB add-on runs out, will that option appear again or it won’t until 10 days period have run out.
11-09-2017 06:22 PM
@will13am wrote:Unfortunately this is the limitation of how these US add-ons are set up. I suggest private messaging the moderator team to see what they can do to enable repurchasing an add-on before the 10 day window is up.
Yes, unfortunately that's the only option until and unless PM changes the Roaming options around.
11-09-2017 03:00 PM
