US Data Add-on renewal
bernzieb
Hi there,
I purchased the 1GB US data add-on, it was not enough for this trip and I would like to add another 1GB add-on. The choice has disappeared from the add-on menu.
Thanks!
1 REPLY 1
matbasm
@bernzieb,  If the original 10 days hasn't fully passed, you cannot add another of the same add-on through your self serve portal.  However, If you send a private message to the moderators team, they should be able to do it for you.
Click here to send them a private message.
Information regarding the moderators team can be found by following this link.
