01-18-2018 09:55 AM - edited 01-04-2022 03:20 PM
01-18-2018 01:47 PM
Looks like you purchased this add-on less than 10 days ago. It will show up again once 10 days period expires.
01-18-2018 12:07 PM
first you have to go to your account to you sign in
on top of my account not on community
and your first page you see
my Data & Add-Ons and Click on Purchase Add-ons
and choice what do you like to add on your account it's too easy
good luck
01-18-2018 10:25 AM
Which plan do you have? Does your plan have data?
Are you sure you didn't buy it already? Which Add-ons are shown under My Add-ons on the Plan and Add-ons page?
Add-ons either don't appear for buying because your plan does not support them (such as you can't buy Talk add-on if your plan has no Talk feature) or because you've already bought that add-on.
01-18-2018 10:23 AM
Hi @yyzr,
The add-on shows up properly for me as well.
Have you purchased this add-on previously and used up the full 10 days already? That could be the reason why it is gone from your options.
Could you try dialing 611 (or 1-855-4PUBLIC if outside of Canada) to see if you are able to purchase the add-on over the phone?
If the above does not work, I would send a message to the Moderators for help, using the below link (be sure to include your account number, phone number, e-mail, and pin):
01-18-2018 10:08 AM
Yeah. It isn't showing up in mine. Only bundle that is showing up is Talk+text for $15
01-18-2018 10:07 AM
Do you mean the talk + text + 250MB data for 10 days? It shows up as available in my self-serve.
