07-22-2024 10:21 AM
I am from Canada but going to the USA for vacation. What add on do I need to use my cell in the USA and not be charged crazy usage fees to use my phone?
07-22-2024 11:46 AM
PM is a prepaid service so if you don’t purchase an Add-on…you won’t be charge.
If you are just looking for calling and texting. Just download the WhatsApp or TextNow app for free calling and texting when you connect to wifi.
07-22-2024 10:40 AM
@Jojo78 , what plan do you currently have? The lowest priced CAN-US plan which incorporates roaming into the plan is $34. If you travel a reasonable number of times to the US, that might be an option over buying roaming add-ons. Also calls to the US from Canada are included.
07-22-2024 10:23 AM
if you just going US for a short trip, you can buy one of the US roaming add-ons. There are different one to choose:
Bundle - US Roaming - Talk, Text and 3GB Data (15 days)- $30 (25 Reward points)
Bundle - US Roaming - Talk and Text (15 days) - $15 (10 Reward points)
Data - US Roaming - 250 MB Data (15 days) - $10.00 (5 Reward points)
Data - US Roaming - 1GB Data (15 days) - $20.00 (15 Reward points)
Data - US Roaming - 3GB Data (15 days) - $25.00 (20 Reward points)
US data has a 15 days expiry, it will start right after the purchase is completed successfully. So, you can wait till closer to your trip to buy it
Also, a reminder, when you are in US, make sure you try to connect to T-Mobile and AT&T network. If it does not connect automatically, then change the Network connection to manual and select try T-Mobile and AT&T manuall.
If you roaming purchase includes data, make sure you enable Roaming Mobile Data on your phone. Change network mode to 4G/LTE
If your roaming purchase includes voice, enable VoLTE on your device and you might be able to use VoLTE for voice. But if not, your phone should change to 2G network on T-Mobile ONLY and test voice calls
07-22-2024 10:22 AM
do you need data or voice ? they have different roaming add-on depends on your need
