11-25-2023 12:56 AM
UNABLE TO SUBMIT A TICKET TO CANCEL MY ACCOUNT. THE PAGE EITHER GETS STUCK LOADING OR SHOWS 404
11-25-2023 02:53 AM
System back online, I am able to login and switch to 5G $34/40GB plan.at 23:30 Vancouver time.
11-25-2023 01:02 AM
@Tmoney Yes if doing it from scratch , but that link provides the CS_Agent in the to field , just need to type your message and send with that link
11-25-2023 01:01 AM - edited 11-28-2023 01:19 PM
@canada2023 you want to just "cancel" the account and don't need to port out the number?
If port out is needed, you still need an active PM account
if just cancel, it is hard to login My Account today, but if you can login, disable Autopay (not called Subscribed) under Payment page, Manage Subscription
or if you know the 4 digits pin, you can disable by dialing *611
11-25-2023 01:00 AM
I got confused with this instruction before, you actually need to type in " cs_agent" in the to field and send a message to them.
11-25-2023 12:59 AM
Been refreshing it all day! My account won't set up either. At this point I just want to cancel the whole thing, but that isn't possible without submitting a TICKET??? Which is down right now
11-25-2023 12:58 AM
yes, chatbot has problem with ticket (nothing to do with today's server problem), please private message agent instead:
11-25-2023 12:57 AM
@canada2023 You can use this direct link to submit ticket with support
send a private message To CS_Agents click
VVVVV Link below VVVVV
11-25-2023 12:57 AM
system crashes, try to refresh!
