U.S. talk, text, data plan issue
08-08-2017 11:36 AM - edited 01-04-2022 02:27 PM
I bought the US talk, text, and data plan for a trip to the US a few weeks ago. During my stay south of the border I had to make a few very important scheduled phone calls to Germany which is why I had bought the $ 20 add-on. Since I also have the international calling add-on as well, I was confident that calling internationally would not be an issue.
However, while in the U.S. I was never able to call Germany (neither cell phone or land line) which was a serious issue for my business.
Please explain.
08-09-2017 09:58 AM
Thanks @CS_Agent Saray,
Unfortunately, it is not clear on your website that your roaming add-on cannot be used to call Germany from the U.S. An update would be great so no one else has the same issue I experienced.
Would you be able to credit my account for the $20 add-on I couldnt' use as intended?
Bettina
08-08-2017 12:16 PM
I wouldn't recommend using public mobile as business phone like that. There are too many hoops. I would have just suggested not getting calling addon and just using some VOIP in the USA to call germany. Cost would be next to nothing.
08-08-2017 11:54 AM
Hey @bettina,
I'm sorry you missed some important calls while you were in the U.S. Unfortunately, the U.S. roaming add-ons only allow calls and texts from/to the U.S. and Canada. Our roaming add-ons cannot be used in combination with the long distance add-ons.
Don't hesitate to send us a private message if you have any other questions 🙂
@ShawnC13 and @Nsk143 - thank you btw 😄
Saray
08-08-2017 11:51 AM
Here's a chart showing which calls you can make from where to where with the various plans and add-ons:
08-08-2017 11:45 AM
It's probably only works when you in your home region. Using u.s roaming its already an add-on and then using long distance add-on while Using u.s roaming. I have a doubt its won't work like that.
08-08-2017 11:42 AM
@bettina, sorry to hear you had these issues. The international Long distance calling is while you are on the HOME network. When travelling to the US you aren't on the home network and I don't think any of the other addons would be active.
