07-17-2022 07:28 PM
Anyone else trying to upgrade to the 4g plan and having trouble where to find it? I checked all over my account and how to upgrade but it doesn’t give me an 4g upgrades? Any help appreciated
07-17-2022 11:08 PM
Hope you will able to navigate the change. Good luck with the 4G plan, keep us updated on how it goes and how much of a difference it is for you.
07-17-2022 08:11 PM - edited 07-17-2022 08:19 PM
Not only are the arrows used to select the plan, but the arrows also need to be clicked ln to see the other plans. Unfortunately, they're not alll visible on the page at the same time.
07-17-2022 07:54 PM
@Kauaigirl7 wrote:Anyone else trying to upgrade to the 4g plan and having trouble where to find it? I checked all over my account and how to upgrade but it doesn’t give me an 4g upgrades? Any help appreciated
07-17-2022 07:31 PM - edited 07-17-2022 07:33 PM
@Kauaigirl7 hi in your account under plans go to change plans, use the down arrow to scroll down they are there
07-17-2022 07:30 PM
clear cache and cookies and use inPrivate mode,
or tried other browser
