Trying to port number from virgun
03-10-2019 01:35 PM - edited 01-05-2022 03:39 AM
Trying to port number from vernon got the info wrong once and now it won't let me try anymore
Phones
03-10-2019 02:02 PM - edited 03-10-2019 02:03 PM
@Geejustin66 wrote:Trying to port number from vernon got the info wrong once and now it won't let me try anymore
Is your Virgin number showing on your your phone using PM SIM card?
If yes, PM is already started the porting process.
If no, restart your browser and initiatte the porting process again.
PM self-serve portal does not like go back a page. Always restart browser and do the process again after going back a page.
03-10-2019 01:38 PM
If you have problem with the page of activation you can use a different browser or an incognito mode...
If you made a mistake during the port you will need help from the moderator...here..https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437 and give them details of your problem...waiting time is few hours to 2 days..
