Troublesome caller
pdolphin
I was wondering if there is some way I can block a specific incoming caller that is troublesome from using my voicemail? Thank you for helping!
Nothing Public Mobile can do to prevent a number from connecting to your voicemail @pdolphin .
will13am
@pdolphin , blocking can be done on the phone app.  This is what would happen on an android device.  I assume something similar for iPhones.
https://support.google.com/phoneapp/answer/3459196?hl=en#:~:text=Turn%20See%20caller%20%26%20spam%20....
@pdolphin
Unfortunately, if you block the number on your phone your phone won’t ring but It will go to voicemail.
