10-22-2025
03:01 PM
10-22-2025
03:04 PM
computergeek541
I tried transferring my old Koodo number to Public Mobile today. I replied YES to the Koodo confirmation text, but the system said there was a problem transferring my number. My SIM now shows SOS only. What should I do now?
edited by computergeek541: changed category label as this discussion isn't related to Community
10-22-2025 03:06 PM
@slusagm wrote:Your sim shows SOS means you don't just have porting problems but also account setup problem. You need PM to help
Maybe, but maybe not as I can't tell which SIM cards the customer is using while the phone is in SOS mode.
10-22-2025 03:05 PM
Hello there.
I sent you a private message.
You can view and reply to it by accessing this link:
10-22-2025 03:03 PM
Since you cannot properly login, you won't be able to open the preferred Chatbot ticket. So, you will need to message them here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
https://productioncommunity.publicmobile.ca/t5/notes/privatenote
