11-10-2020 08:59 PM - edited 01-05-2022 04:04 PM
Hi I'm with Koodo and I'm having problems transfering my number over to public mobile and on top of that I can't book a ticket.
11-14-2020 06:29 AM
Welcome to Public Mobile. 🙂
11-13-2020 09:22 PM
@reddysar7 wrote:Please try to connect with Public mobile chat , they can help you on your issue.
Find online chat link below
https://chat.telus.com/chat/publicmobile/chat-pm.html?portal=publicmobile&language=en
Doing this would only work if the customer hasn't already activated the Public Mobile account. If the Public Mobile account has already been opened, the people running the live chat cannot help.
11-13-2020 05:59 PM
11-10-2020 09:05 PM
Good evening,
I can help you with this. To transfer you would have to keep your current plan active and make sure you’ve paid off your phone so that it’s unlocked. You can transfer in 2 ways, in store or online.
You can find a location nearest to you below and bring in your phone and Koodo account number:
https://www.publicmobile.ca/en/on/store-locator
Now to do this online you would have to buy a SIM card which will be delivered to you:
https://public-mobile.myshopify.com/cart/add?id=5876039041
Once you receive it you will activate it below:
https://activate.publicmobile.ca/
11-10-2020 09:03 PM - last edited on 02-03-2021 06:30 PM by Ioana_R
@Alek69 Port Fraud Protection (publicmobile.ca)
"Porting Your Number Into Public Mobile
If you are porting your number into Public Mobile, for additional security, your previous service provider may also send an SMS text to validate the transfer. Follow the instructions in the message within 90 minutes to approve the number transfer.If you have missed the 90 minute window to respond, we will send you an SMS with instructions on how to re-initiate the transfer by calling our Porting team.The SMS will read as follows:Public Mobile Msg: The request to move your phone number to Public Mobile has timed out. Don't worry, you can easily re-initiate the transfer. Please call our Porting Team at ***to authorize your number transfer
Tips:
11-10-2020 09:01 PM - edited 11-10-2020 09:07 PM
@Alek69 wrote:Hi I'm with Koodo and I'm having problems transfering my number over to public mobile and on top of that I can't book a ticket.
Create a moderator support ticket for help using the Chat button at the bottom right corner of this page.
Tell SIMon what is the issue (important) - Use "Port Request"
Telus, Koodo and PM have implemented port fraud protection.
After initiated port request, you should continue to use your Koodo SIM card to receive port confirmation text message. You need to reply to your Koodo text before Koodo will release your phone number to PM.
https://www.publicmobile.ca/en/bc/get-help/articles/port-fraud-protection
