08-02-2019 12:23 PM - edited 01-05-2022 06:14 AM
08-02-2019 04:32 PM
Yes, I provided my Koodo cellphone #, my alternate phone # and my Koodo account #. I am keeping my Koodo cellphone # active until I hear from the PM moderators. Thankis for the advice.
08-02-2019 03:13 PM
@denisal wrote:I understood the process you suggest only worked for the Koodo post-paid accounts. Did I misunderstood?
@denisal You are correct. Did the moderator ask you to verify your account yet? Hopefully you included all the required info, Koodo acct#, name on account and number in your original message. If yes, best to take @LovesToPM recommendation and continue to use your Koodo sim until it stops working.
08-02-2019 03:07 PM
@denisalIt requires Moderator intervention because Koodo Prepaid and Public Mobile shares the same system.. you message the moderators.. the moderators have to go and declipher all the other messages (billing etc etc) to find your port message.. vs having a port request right there in the porting work pile. My suggestion submit it anyways.
08-02-2019 03:00 PM
@denisal wrote:My request to the moderators was for a cellphone number transfer from a Koodo prepaid account. I read that this is the only way to proceed. So ... I guess I'll try to be patient. Thanks for letting me know that the wait time can be as long as 48 hours.
While your're waiting for Moderator to complete the port, you can continue to use your Koodo SIM.
Once it stops working, you'll know the port transfer is complete.
08-02-2019 02:22 PM - edited 08-02-2019 02:31 PM
You are absolutely right, we just didn't know
08-02-2019 02:16 PM
08-02-2019 01:53 PM
@denisalYou can try the online form and get at least some of the information to the Moderators.. then message them to intervene. You can initiate the port via selfserve.
08-02-2019 01:36 PM
08-02-2019 12:47 PM
@denisal wrote:I have sent a private message request to the moderators' email account yesterday morning but have yet to hear from anyone there. Are they on vacation? What is the time-lag to expect a reply from them?
Denis
No they work on weekends and holidays too, there is just lots of problems for some reason now and wait times to to48 hours.
You can wait or you can post your question to community and see if anybody can help you resolve it by yourself
08-02-2019 12:44 PM
Denis
08-02-2019 12:43 PM
Did you setup your self serve account
You first need to do that here https://selfserve.publicmobile.ca/self-registration/
Are you prepaid or post paid
If post paid or if you are not sure log in to your selfserve and go to plan and add-on tab, then change phone number tab, then choose option to port and enter your koodo number and fill in the information
If prepaid message moderators here https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
Yon may have to wait for long time
08-02-2019 12:37 PM
@Mpeters19 wrote:My Koodo account number is 10000xxxxxxxxxxxxxxx
@Mpeters19 Click on the three dots select Edit Post and remove your private info ASAP.
08-02-2019 12:35 PM - edited 08-02-2019 12:36 PM
@Mpeters19 wrote:I am wanting too transfer my number xxxxxxxxxxxxxxx from Koodo too Public mobile. My Public mobile number I chose temporarily to setup my account is xxxxxxxxx
@Mpeters19 This is a public forum so you need to edit your post and remove your phone infomation for your protection.
Did you pay monthly for your previous Koodo account or every 30 days? If you paid monthly then use selfserve. If you paid every 30 days then contact the moderator team as mentioned above.
08-02-2019 12:35 PM
@Mpeters19 This is a public community forum. Please do not post personal information.
You can click on the 3-dots on on top right corner of your post to edit it.
08-02-2019 12:33 PM - edited 08-02-2019 12:36 PM
08-02-2019 12:32 PM - edited 08-02-2019 12:37 PM
08-02-2019 12:31 PM - edited 08-02-2019 01:00 PM
@Mpeters19 If it's Koodo postpaid you can do it through selfserve. Login and choose the change phone number option,
If it's a Koodo prepaid account you need to message the moderator team to do it manually. Just include your Koodo account#, Name and phone number and also your current PM (if you picked a temp one).
To contact Public Mobile click here. The link sends you to the private message function and adds the moderator team as recipient for a private message. You just have to enter a title and text in the body of the message describing the problem and post. The message will be received by the moderator team and they will respond to it. You will receive the response in your private message inbox.
Moderators are available: M-F from 8 AM to midnight Eastern time and S-S from 8 AM to 10 PM Eastern time.
Note: Moderator Hours are subject to change, but you can always find the current times here
08-02-2019 12:27 PM - edited 08-02-2019 12:32 PM
@Mpeters19 wrote:How do I transfer my koodo number over to public mobile?
Choose your Phone Number
You can transfer your number from another provider or select a new number. In either case, here’s what you should know:
| Mobile Phone Number Transfer | Landline Phone Number Transfer |
| Alternate Phone Number | Complete billing address |
| First and Last Name of the account holder | Alternate phone number |
| You’ll also need to provide one of the following: your old account number | First and last name of the account holder |
