Transfer to Replacement Phone
Lab
Can I transfer my account to a replacement phone. If so, how do I do that?
7 REPLIES 7
CS_Agent
Hi there Lab,
You need to make sure that the phone is unlocked, if it's unlocked just switch the sim card to that phone.
To know if it's unlocked, just put in your sim card in it, if it says "unlock network pin required" it means you'll need to contact the carrier from where you purchased the phone to get it unlocked.
Kind Regards,
Rod,
Public Mobile Moderator Team.
m0neywise
If it is an older phone you have to make sure that it is not locked to another network.
wickedgx
As long as your replacement phone works with Public Mobile, the SIM card that connects you to the network will have the same phone number no matter how many times you switch phones.
You can test your phone compatibilty here @Lab willmyphonework...not perfect but good.
Metal1967
@Lab wrote:
Does my number transfer with the sim card?
@Lab
Yes it does...
Lab
Metal1967
@Lab
As long as the phone is compatible with public mobile just put your sim card in it...
