3 hours ago
- last edited
2 hours ago
computergeek541
Hi. I've just activated, with a PublicM mobile provided number. I want to use this for a few weeks, and then if all is good I'd like to port my existing Telus number over to PublicM and use that going forward instead Can that be done via self service?
3 hours ago - last edited 3 hours ago
@Alandee Yes absolutely when if you want to port your number over just do so in your account profile page . And remember to leave your Telus SIM card in the phone to reply YES to the confirmation text to port . Also just use your Telus account number and ignore the IMEI it’s not needed and often causes hiccups
notice transfer number under the red circle in pic to get started @Alandee
Change # on profile tabs
