07-22-2020 11:20 PM - edited 01-05-2022 12:13 PM
I top up my phone & my son’s phone yesterday in a convenience store but I did not receive it what should I do?
07-23-2020 10:56 AM
Once activated you should receive a text message confirmation.
If you didn't get instant confirmation it was possibly a pin you purchased for top up that would need to be plugged in on your self-serve account to activate the top-up / tie it to his phone number.
Check on the receipt to see if there was a pin that you can then use.
In future an easier way to get add-ons may be to use the self-service application (https://selfserve.publicmobile.ca/), on the left hand side should be a "purchase add-ons" button, from there it gives you an array of options to select from that will be instantly added to your phone if you have sufficient funds in your account.
07-22-2020 11:23 PM - edited 07-22-2020 11:56 PM
@Karen_1976 Did you purchase a voucher PIN or instant top up? I think you should get a text message if it was applied directly to your account using your phone number. If you purchased a voucher pin, it should be on the receipt.
If you need to contact PM Customer Support Agent, Start a Chat to Create a Ticket OR visit the Get Help page.
