They cut off my data
Jay6
I bought the 8 gigabyte plan they shut it off before I use five I want my other three gates either that or give me my f****** money back
mimmo
@Jay6  public typically does not shut off data either you used it up and it does not show on self serve or your phone has a limit and it cut you off.
As a side note using **** is just the same as using the full expletive and has no use here in the community.
cavemantoronto
@Jay6 Are you on a $40 or $50 plan?
darlicious
@Jay6  When you log into your account...on the overview page what does it say in the "Your plan and add ons" section?
