01-11-2024 07:10 PM - last edited on 01-12-2024 04:41 AM by computergeek541
On our Samsung S20FE the replies to a text are received before the phone shows the the question has been sent.
01-15-2024 11:20 PM
Clear your sms messages cache and reboot your device. Also check for any updates.
01-11-2024 07:14 PM
@Lin2 wow that’s creepy LOL never heard that issues before . Have you tried rebooting the phone ?? Are you able to test the SIM card in another phone and test it ?? Can also try to reset network settings but doing this will erase your saved wifi passwords and you will need to re enter them . If still no luck you can submit ticket with support to investigate
send a private message To CS_Agents
01-11-2024 07:14 PM
Sounds like a phone issue. I have this phone and that does not happen to me. Maybe see if there If an update pending and update it. Check the settings in the message app
