4 hours ago
Text messages won't send to someone in my contact list. This just started today.
4 hours ago
More details would be helpful.
Does data work? calling work? Is your account status active versus suspended?
Might want to try a simple reboot of your phone.
4 hours ago
would be helpful if you tell us if you are using iMessage or Android
if iMessage, are you really sending text? try toggle of Send as Text and reboot and toggle it back on
if Android, try clear cache first on the message app. If still fails, try clear data if you are willing to delete everything on it
and are you using Google Message? or other message app?
