Text
04-29-2020 12:05 PM - edited 01-05-2022 10:34 AM
04-29-2020 02:00 PM
@Shaya916 reset your network settings
1. From the home screen navigate to Settings>General>Reset
2. Tap Reset Network Settings
If prompted enter your passcode
3. Tap Reset Network Settings
4. Restart your phone
04-29-2020 01:08 PM
If the suggestions have failed perhaps contact the moderators.
Click on the green questionmark in the white circle at the bottom right of your screen. This connects to the autobot Simon. Type moderator and follow the prompts to get to one (CLICK on "Account specific question" and "No I want a human" and "Submit a ticket Click me!")
Once connected, you will be asked to log in again with your community user name and password. Please do, this allows you to continue and send your message.
Check your private message sent box (click on the envelope top right of your screen) to make sure the message was sent. Also keep an eye on the envelope, the mods answer will show up there. Once it does, you will be asked to verify your self service account, with your password and login. Doing so allows the process to continue.
04-29-2020 12:24 PM - edited 04-29-2020 12:25 PM
Go to your settings app then messages and locate the switch for "send as SMS" turn it on. If it's already on turn off for 10 seconds then turn back on and try to send your text.
You may be having difficulty with iMessages vs SMS .
04-29-2020 12:17 PM - edited 04-29-2020 12:17 PM
@Shaya916 Hi is it a blue iMessage that you were trying to send or is it a green text?
04-29-2020 12:10 PM
I done this several time and my signal shows 2bars on an iphone 8
04-29-2020 12:07 PM - edited 04-29-2020 12:09 PM
@Shaya916 Your account is active right? How strong is your phone signal? Try to turn off your phone for several mins and turn it back. If didn't work, try to enable fly mode for several mins and then disable.
If the methods didn't work, and your signal is strong, I would personally
contact moderators through clicking on ? on bottom right of the page and following directions. I had the same issue with my phone. When I asked them what is the problem, they restarted my account from their end, and it fixed the issue.
