Text with pictures
Charlielou
Hi I couldn't do texting with pictures attaching eventhough I have the plan please advise thanks
9 REPLIES 9
Andy85
Have you viewed the settings within the text message conversation? In my experiences, that is the location where I am able to enable MMS file transfers.
what exact Samsung model?
Please try update APN on your phone
APN: sp.mb.com
MMSC proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
Charlielou
I turned on the Data but still not working not sure why. My wife used a Samsung and she told me to turn on Data but it refused to work
Charlielou
Where do I enable MMS
Charlielou
I enabled the data but still not working
@slusagm
Opps, I meant cellular data.
@BKNS27 wrote:
@Charlielou
You will need to enable MMS and Roaming on your phone.
why need roaming enabled?
MMS just need data enabled but not roaming
@Charlielou
You will need to enable MMS and cellular data on your phone.
slusagm
what phone do you have?
Try Reset All Networks and check if it fixes it
but some older Android phone might not work with MMS or might need APN update
