Text re switch to telus
dianeic
Got a text saying network won't work after march 2027 is this true @members
@dianeic
All phone has to be on PM's VoLTE to be able to make calls after 3G is retired.
So, While your phone has VoLTE, it can still be not compatible with PM network.  Your phone will still work in NS for now, but vice calls  will stop working next year when 3G is decommissioned there.  Many in Manitoba ignored the VoLTE warning and hence not able to make calls now.  Please plan ahead early for another phone
dianeic
I'm in nova scotia and I did the checker and it said not compatible but if I check my about phone it says I'm have VoLTE
@dianeic
What phone do you have? Which province you are in?
First, use the IMEI checker on this page to see if your phone is compatible with PM's VoLTE network:  https://www.publicmobile.ca/en/on/get-help/articles/volte
If it has a VoLTE checkmark showing in the checker result, then there is nothing to worry about
If it is not compatible with PM's VoLTE, then your phone had been using 3G for voice and is now affected by the 3G Network Shutdown that has just started in Manitoba:
https://www.publicmobile.ca/en/get-help/articles/3g-shutdown
If you’re using a 3G-only device, your phone will stop working after these dates:
Manitoba (Rural): January 12, 2026
Manitoba (Urban : Winnipeg & Brandon): Starting March 31, 2026
National: Starting March 1, 2027
If the lack of VoLTE support is what affecting your voice calls, there is really nothing much you can do other than getting a phone that is compatible with PM's VoLTE network.
iPhones 8 or later, Google Pixel 4 or later, Samsung S22/Flip 2/Fold 2/A15/A35/A55 or later, or other major brands of phones released after 2024 and are designed and sold for the Canadian market should work.
If you are unsure whether a particular phone will work, share the model here and we can help
