Text messages
jordanfaulkner
Not receiving any texts from anybody , is this normal
people are getting my texts but I’m not getting any texts back
2 REPLIES 2
PublicTech
@jordanfaulkner There are some really good suggestions by @softech! Another thing you can try is removing the SIM from your phone. I have had this happen to me in the past with a different service provider, all my texts and calls would send but I couldn't receive anything. If this does fix it and the problem returns, you may want to look at replacing your SIM card as a potential fix.
@jordanfaulkner did you just join PM and requested to port the number into PM?? if so, can you double check to confirm if you are receiving incoming calls?  If no incoming calls and text, it would be a stuck port, the port was not completed.  Let us know, there is a number to call to sort it out
if you have been with PM for some time and just having text issue today, then try to clear message cache and try changing the Preferred network type to 3G
