Text message on bluetooth with vehicle not reading senders name any longer
10-15-2019 08:37 PM - edited 01-05-2022 07:35 AM
I used to get text messages through the vehicle and it would tell me who it was from so I would know if I wanted to listen to it or not. Now it tells me an unknown caller even though it is someone's phone number that is programed into the phone, and someone's phone number I used to have no problem having the vehicle recongnize.
Phones
10-16-2019 08:18 PM
Previous provider was Telus. As for those other questions, I will have to look into it.
10-16-2019 07:19 PM - edited 10-16-2019 07:22 PM
@LoriBree Sounds like you car's bluetooth needs to update your phone's contact list again. Can you dial a number using your car's call button?
Edit: Note that PM uses 3G for calling does your car's BT require a LTE connection for calling? WHo was your previous provider?
10-16-2019 07:08 PM
So disconnecting and reconnecting did not make a difference. Still telling me incoming text messages are unknown number even though I have received texts from these people before and the vehicle has recognized their number and say their name. Since I changed to public mobility it is no longer doing that.
10-15-2019 10:00 PM
Will look at doing it tomorrow. Thanks again.
10-15-2019 09:37 PM
@LoriBree definitely worth a try.🙂
10-15-2019 09:32 PM
I'm not sure but the BT does not disconnect. I am thinking maybe if I disconnect and reconnect the BT it might straighten out. New provider may have to reset the connection with the vehicle. Thoughts?
10-15-2019 09:21 PM
@LoriBree Do your contacts get updated automatically everytime you connect to your vehicle's BT?
10-15-2019 08:41 PM
yes
10-15-2019 08:40 PM
@LoriBree Same phone?
