Text for loyalty
PMGUY01
I would like to text customer service got a text for free 10 gigs per month for 12 months loyalty was there said 40 gigs total now that ten gigs disappeared from my account but was successfully added last month.
hi @PMGUY01
if it is dropped off already, it could means you already used 10GB, the 2GB you see could actually means 10GB already used up from the bonus data, and  2 extra GB from your monthly data
So, you should check with PM support agent directly and they can confirm
submit a ticket with CS Agent using Chatbot here:
             Type the question "Ticket", Then click the following in order: "Account Management" , "Log In".
             (If unable to receive 2FA SMS, click "Didn't Receive Code" or "Resend Code" and Select "Send Email")
If any issue with ticket submission, you can submit  ticket by direct message:
PMGUY01
oh I didn’t use 10 gigs was lucky if I used 2 gigs
hi @PMGUY01
yes, you used up and it will disappear, then it will reappear on new cycle
this is how this add-on will be shown.  So, it is normal
PMGUY01
Oh the loyalty 10 gigs per month for 12 months is not showing up in the usage breakdown anymore. But it was there last month  when it was offered and accepted.
hi @PMGUY01
it is normal the 10GB per month data will disappear temporary, but it will reappear when a new cycle starts.  I have gone through the same and this is the how it supposed to show on the Usage breakdown
