Text Message
Louise123
Hi,
My boyfrend is not getting my Text Messages, everyone else is receiveing them but not him.
I receive his Texts, Calls, voice messages and emails but not my Texts.
Thanks,
L
Pier
Hi,
Sorry to hear the problem, but that has nothing to see with you (PB) as you said everyone else gets your texts messages but him. So, ask him to apply the process that has posted by Jeremy_M.
Good luck!
Louise123
Hi,
I am useing a LG phone and his is a I Phone.
Thanks,
L
Jeremy_M
Retraité / Retired
Retraité / Retired
Hey @Louise123,
Welcome to the Community, and thanks for taking the time and posting your question:)
If you're using an iPhone, try the following:
go to Settings > Messages and make sure Send as SMS is turned on.  If he isn't on an iDevice (iPhone, iPad, iTouch, etc) You may also want to scroll down and make sure the MMS Messaging is turn on as well while you're doing the above.
If the above does not apply to you, try doing the following:
  • Ask your BF to delete your contact from the phone and add it back (Test)
  • Verify if your BF didn't mistakenly block you Smiley Embarassed
Please advise if the above helped or not:)
Cheers,
Jeremy
